CA_Traveler
Jan 01, 2015Explorer III
BFL13 wrote:And that is exactly my point! With the low cost of DC clampon meters why would you even consider cutting or opening wires for a serial connected meter versa a clampon???
Rather than the $10 type, which fry if you go over the 10amp limit, I now like the more expensive version that has a fuse in it. I am now ahead on the money buying fuses instead of new meters. :)
And here's my trick - Opening a circuit can and sometimes does change the conditions that you were trying to measure and hence the measurements isn't related to the original cause.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
