WyoTraveler
Jan 01, 2015Explorer
CA Traveler wrote:BFL13 wrote:And that is exactly my point! With the low cost of DC clampon meters why would you even consider cutting or opening wires for a serial connected meter versa a clampon???
Rather than the $10 type, which fry if you go over the 10amp limit, I now like the more expensive version that has a fuse in it. I am now ahead on the money buying fuses instead of new meters. :)
And here's my trick - Opening a circuit can and sometimes does change the conditions that you were trying to measure and hence the measurements isn't related to the original cause.
I use a small needle and poke through insulation.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
