dons2346
Jan 01, 2015Explorer
Back when I was a working stiff, I did a lot of troubleshooting of some pretty high tech electronic equipment. Never needed to poke a hole in the insulation. If I was a automotive type guy, I would have something like THIS to assist me in troubleshooting problems. In fact I do have a similar OBD reader and have diagnosed some problems on my Jeep.
Salvo wrote:
From your comments, I take it you don't do much troubleshooting.
Inserting a needle probe into wire insulation is an excellent way to troubleshoot. For example, in a car, how do you determine if the lambda sensor is functioning with just home mechanic tools? You got to probe the sensor wire.dons2346 wrote:
An excellent way to create problems down the road. Water can get into the wiring and will cause corrosion which will eat up the wire strands and cause a reduction in current carrying capability.
It might not happen this year or the next but sometime down the line, you will have a corroded wire.
This is not a good troubleshooting technique.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
