KD4UPL
Nov 25, 2021Explorer II
DC amperage is very hand around an RV where nearly everything is DC. Is this a clamp on amp meter or do you have to insert the probes into the cirucit? I prefer the clamp style as it's much easier to use and will read much higher currents. If you ever need to measure DC current from a solar array or to an inverter you will appreciate the clamp DC meter.
I wouldn't buy anything electrical from HF. If you're going to invest in a tool invest in a good one. Fluke is the top of the heap but I'd take Klein, Southwire, or Ideal any day.
Keep in mind, with cheap HF meters, you will have live electrical power flowing thur this device. A cheap meter that blows up in your hand is a really bad deal.
