valhalla360
Nov 25, 2021Navigator
For starter, a cheap $10-20 unit will be fine.
Checking amperage is far less commo but even the cheap ones will typically do 12v up to around 10amps. The downside is you have to put it in the circuit. The more expensive clamp on meters don't require the wires to be disconnected.
