Kansas_couple's avatar
Nov 25, 2021
Multimeter recommendation?
I'm looking to buy a multimeter, as my rig's refrigerator doesn't work on electric but still works on gas. There is power to its outlet (of course, that would be too easy of a fix..) and I know my next steps will involve going to the circuit board. I'm looking at the Klein Tools multimeters they sell at Home Depot. Noticed the CL 390 can measure DC amperage. Would this be something to have, or is measuring DC current not that important? If not, then I'd go with one of the less-expensive models. I'm open to thoughts and input. Thanks!
  • Buy the best you can afford. Frequently, when you have an electrical problem, others here can suggest tests to be made to find the problem. You may not know how to do the tests but others can guide you through it. Meter readings are essential for a rapid solution. No meter, no solution.
    Also, in the course of doing the above, you will learn tricks to put in your memory bag.
    P.S. having an amp meter can be very helpful.
  • Seon's avatar
    Seon
    Explorer II
    Buy a cheap Harbor Freight meter if that's all you're doing.
    https://www.harborfreight.com/7-function-digital-multimeter-63759.html
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
