Harvey51's avatar
Harvey51
Multimeter UNI-T UT55 problem
If you have a UT55 and blow a fuse, be careful how you take it apart!
I had the bad luck that when I took the back off, the circuit board stuck to the front - and I stupidly took some screws out of the back of the circuit board thinking it was attached. It wasn't but the black range dial mechanism was - and it fell off when I finally pried the board off the front. Pieces all over the place. Two ball bearings and a rotor with 5 springy contacts. This photo shows it as it should be. Note the four screws & nuts showing around the black dial mechanism:
This next picture shows the contacts on the dial (upside down); each copper colored spring connects a circuit board contact in one ring to another in the adjacent circular pattern of contacts.
I think only one of these spring contacts fell out (bottom one on the outside) and I thought I put it back in the same place. But it doesn't work.
I have not dared try measuring a voltage, just the ohms range. It shows a big 1 with no connection and, briefly a number when shorted, then goes back to 1. I'm thinking that could only be because I have one of the contacts in the wrong place. There are 8 other places to put that one on the bottom.
Can anyone think of a way other than trial and error to fix it? It is a tricky little job to reassemble the black dial with two spring loaded ball bearings. I did write to UNI T in Hong Kong but no replay after 2 days.
  • I don't know anything about that particular meter but here are a couple of ideas.
    1) Look for wear marks on the circuit board to indicate where the springs may have traveled.
    2) Most likely no 2 springs travel in the same circle on the circuit board. The picture seems to show 2 on the outer circle of the selector.
  • You're a better person than me. I would have have pitched it and got out one of my many free multimeters from Harbor Freight. :)
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
