- dannytasExplorerIn our Fleetwood Tioga SL "C" class we had a main switch in the panel and secondary switch in the bathroom. That was a real conveience when I forgot to turn it on.
All our other RVs only had one switch on the panel. I wanted to add another switch. Then someone told me just to keep the switch on. So I do and we always have water. :D - C_SchomerExplorerMaybe a wireless remote. I knew a guy who put one on his rotophase so he could control it from anywhere in his shop. Craig
- BumpyroadExplorer
jauguston wrote:
Running new wiring in a already built RV can be a daunting task.
yep, getting the mechanical parts is a small part of the problem.
bumpy - wnjjExplorer III added a second switch to our camper's pump a few year ago. We use it all of the time.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24397265.cfm - jaugustonExplorerRunning new wiring in a already built RV can be a daunting task.
- wa8yxmExplorer IIIThere are two ways..
One is to run a latching relay as someone up-thread suggested, This means replacing the switch with a 3=position switch, spring return to center, Depending on teh latching relay will determine the switch but a common one I know of you apply power one way to "CLOSE" and another way to "OPEN" This is the kind you need. This would require running 3 wire cable to each switch SPDT Spring return to center (ON)off(ON). switch. (The prens around (ON) mean momentary).
Option 2 is to use multi-way house switches, Basically the hookup is like this
Original
Fuse---switch---pump
new
Fuse---Switch #1======Switch#2======Switch#3====Last switch----Pump
Note the two wires between the switches
not also that though the 1st and last switches are common 3-way switches, teh two I put in the middle are hen's teath,, (hard to find) you may have to special order those. - dons2346Explorer
Bumpyroad wrote:
RLS7201 wrote:
As Chris previously mentioned, the Intellitec Monoplexer is the easy way to accomplish what you want to do.
Richard
will that let you turn the pump on at one location and then off at another?
bumpy
Yes - BumpyroadExplorer
Richard
bumpy - RLS7201Explorer IIAs Chris previously mentioned, the Intellitec Monoplexer is the easy way to accomplish what you want to do.
Richard - lanerdExplorer II
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
