wa8yxm
Jan 04, 2022Explorer III
thomasmnile wrote:
Might want to read the column from The Verge. Cats in the antenna sounds like the least of Starlink's problems. Yeah I know it's Beta, but sounds like trees and buildings are not its friend.
That is true of ALL satellite services. hughes. Dish network, DirecTV and more.. Trees and buildings block thesignal.
As I understand Star link it may be a bit less suppectable to this. but only a bit.
Still when you are in the land of NO CELL SIGNAL.. it works if you set the dish up in the clear... May be your only option.
Now here is a problem and solution. I have two routers here in teh apartment hooked up as follows
Modem---Router 1 (5GHZ/2.4GHZ)---- router 2 (2.4 only)
Well one device is supposed to be PLUGGED into Router 1.
IT was working (per what it works with) but I could not find it's info page.. So i ask the radio "Where is it" Turns out it was wi-fied to Router 2 (First time that ever worked)
When I moved it 5 feet yesterday I forgot to plug the cable into the router DUH (Face plam) works fine now.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
