pianotuna
Jan 15, 2022Nomad III
n0arp wrote:
Starlink is segmented into geographical service areas, referred to as cells. Each cell has a user limit, as well as other criteria that we aren’t privy to. You have to go into their portal and change your service location, which may be rejected if the cell that contains that service location is full, closed, etc… If you aren’t in or very close to the cell set in their portal, you won’t be able to connect.
So does one set this up over the wobbly wide web? If so that implies one needs to do it before arriving?
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
