CA_Traveler
Apr 15, 2022Explorer III
Rbertalotto wrote:The battery monitor is only measuring power in/out of the battery. The charger is supplying power first to any house loads and then to the battery. Hence normally there will be a difference and your numbers may be correct.You say the recharge went from 60%-100% in 2.5 hrs at 30 amps. That is 2.5 x 30 = 75AH NOT 40AH. So again that 60% SOC must be wrong. You were down to about 25% SOC it seems from that.
You might be right with this observation because I wasn't sure the Aili monitor was reading correctly at first. The only other variable that would affect this test was ambient temperature. The ICECO refrigerator was in a 55 degree garage only looking for 40 degrees. While with the AGM battery we were in summer outdoor heat of 80-85 degrees.
I'm going to modify the article so there is no confusion..
Thanks for your input....
If the charger can't supply enough power for the house loads then the additional power comes from the battery.
