wa8yxm
Apr 15, 2022Explorer III
REe the "Pulled the plug and the battery was still at 60%" (Lithium)
LiFePO4 batteries v/s Lead acid discharge profile.
This is exagrated
Lead acid
Full \
Half f\
Empty -\
Li's
Full------hlf full---- Empty 000000
The full charge voltage is a bit higher than the 90% but the 90% is only a bit higher than the 9% then they drop like a stone
Right now I'm listening to a digital radio
Regular FM as you get farther and farther away from teh transmitter the signal, like a lead acid battery is 5-4-3-2-1-0
Digital 5-5-5-5-0
Your "percent" meter is off.
This is exagrated
Lead acid
Full \
Half f\
Empty -\
Li's
Digital 5-5-5-5-0
