BFL13
Apr 15, 2022Explorer II
People are being careless about saying what they mean in exact terminology, which could lead the unwary into trouble. :(
"Power" is in watt hrs, not AH and is one of WP's sneaky weasel words to do some of his smoke and mirrors stuff. :)
EG, note here what this particular LFP guide says:
" The BMS also disconnects the battery from the load if it is drained to less than 5% remaining charge (an over-discharge condition). An over-discharged battery typically has a voltage less than 11.5V (< 2.8V per cell)."
https://earthxbatteries.com/lithium-battery-series-parallel-operation/
IAW stay above 5% SOC if you can even stop it there (falling very fast)
Some think it is ok to zero% and experience shut off--except this LFP brand's BMS cuts off higher than that at 5%. There is a lot of confusion over how far down is zero!
It is all somewhat farcical IMO, but let's not get 3tons going off his meds again! :(
Point is to do what intinerant1 says, and just avoid the knees completely except the upper knee when needed to synch the monitor.
You absolutely need a monitor with LFPs to be ahead of the BMS cut offs. It is not a happy "look Ma, no hands" deal like some LFP owners seem to be trying to tell everyone.
You have to wonder how all those average RVers who got LFPs recently, who before had no clue how to look after their flooded batts, as is typical of the average RVer, are now able to keep their LFPs from an early death.
