StirCrazy
Apr 15, 2022Moderator
time2roll wrote:jaycocreek wrote:I agree completely. Top at 98% is fine and if it gets to 100% that is fine too. No reason to stop at the bottom except to avoid the point of losing all power at the cut-off.
Never quite understood the need to only use 80%of lifepo4 batteries when there advertised to get 2-3000 cycles at 100% discharge and 10 years service life then you still have 80%capacity after that.,0..That's 5X the average flooded battery and under $400 in some cases....
If I was back full timing, I wouldn't hesitate to use 100% of my lifepo4 batteries..But I'm pretty careful now not to go below 50% on my remaing AGM..lol
when I set mine up I left the top at 100% and set my bottom to 12.1V. will I ever see the bottom, I doubt it unless I decide to install a microwave or something.
Steve
