Itinerant1
Apr 15, 2022Explorer
time2roll wrote:jaycocreek wrote:I agree completely. Top at 98% is fine and if it gets to 100% that is fine too. No reason to stop at the bottom except to avoid the point of losing all power at the cut-off.
Never quite understood the need to only use 80%of lifepo4 batteries when there advertised to get 2-3000 cycles at 100% discharge and 10 years service life then you still have 80%capacity after that.,0..That's 5X the average flooded battery and under $400 in some cases....
If I was back full timing, I wouldn't hesitate to use 100% of my lifepo4 batteries..But I'm pretty careful now not to go below 50% on my remaing AGM..lol
The ones that use lfp understand to use it all if needed or wanting to, if not no big deal. The ones don't use them don't understand that, keep regurgitating longer life but like most things the less you use them.... of course they'll last longer.
