jaycocreek
Apr 15, 2022Explorer II
Directly from Battleborn for anyone whom thinks LVD at 10 volts is harmful to your battery and probably why so many lifepo4 manufacturers claim 2-3000 cycles at 0-100%..Each owner of lifepo4 has that option without harm to the battery..My cheap little volt meters are reading just about the same as my Victron smart shunt making it fairly easy to know about where you are voltage wise....I have run the smart shunt on all three of my LFP batteries taking note of AH and volts of each..Very little difference between the three.
Battleborn wrote:
There is no lasting effect to the battery if it goes into LVD, the LVD protection is implemented to make sure the battery is not too discharged too far and creating damage.
