BFL13
Apr 16, 2022Explorer II
Itinerant1 wrote:BFL13 wrote:
Are those operating from zero to full SOC not hitting LVD at "zero" ? Why not? It is all very strange. What is "zero" is the mystery in that case....
What are you calling zero? SOC zero% = what ever the bms is set for whether 2.8vpc or 11.2v battery pack? If you mean zero voltage... well good chance it's a cooked battery.
You will have to ask jaycocreek what he means by zero for any clarification on that
jaycocreek wrote:
Never quite understood the need to only use 80%of lifepo4 batteries when there advertised to get 2-3000 cycles at 100% discharge and 10 years service life then you still have 80%capacity after that.,0..That's 5X the average flooded battery and under $400 in some cases....
If I was back full timing, I wouldn't hesitate to use 100% of my lifepo4 batteries..But I'm pretty careful now not to go below 50% on my remaing AGM..lol
