time2roll
Apr 16, 2022Nomad
BFL13 wrote:The BMS has sensing wires direct on each of the individual cell terminals. That is all it knows or cares about. If there is undersize wire to the inverter the voltage could be significantly different. BMS does not care if the inverter shuts down for low voltage.
Another thought- the LFP is seeing a loaded voltage at its posts Does the BMS with its wiring see the same loaded V?
