BFL13
Apr 16, 2022Explorer II
time2roll wrote:BFL13 wrote:The prismatic LFP cells are 2.5 volts minimum x4 = 10 volts. However the cut-off is at the cell level so it would be incredibly rare to get all to 2.5 at the same time. Some might be 2.7 -2.9 but the low cell calls it done.
Some think it is ok to zero% and experience shut off--except this LFP brand's BMS cuts off higher than that at 5%. There is a lot of confusion over how far down is zero!
Scroll down a bit for the general specs. Bulk cells on Alibaba
A pre-made battery may allow cells a little beyond the range or a little inside. That is a warranty call made by the builder.
OK, so the monitor measures SOC based on total voltage of the cells, but BMS uses lowest cell.
If not been to 100% and balanced for a while like itinerant1 operates, what is the risk the monitor will not warn in time before BMS LVD?
And that is top balancing
