StirCrazy
Apr 17, 2022Moderator
Itinerant1 wrote:BFL13 wrote:
StirCrazy note that more solar will not save you if sky is overcast. LFP does not change need for gen as back up. Portable gen but not built in is also recovery method for LVD
So true all the extra solar does is allow you to run more items from it and give the batteries a break on the side line waiting for the coach to call them into play when needed while possible still being charged to some degree or after being charged and floating the solar is running the loads if you have enough solar to cover the loads. But when there are multiple days of poor solar or just use alot of power like I do it helps to have a backup plan for charging.
but more solar absolutly does hep asside from hat you mentioned. faster chargingwhen you do have sun. camping in BC is not like camping in California, becasue of the trees you might only get two hours of good sunlight a day and need to take advantage of that.
