Itinerant1
May 01, 2022Explorer
BFL13 wrote:Itinerant1 wrote:
StirCrazy brings up a fair point that the agm pack has to made larger to equal the lfp pack. I think but could be wrong that 800ah lead would be equal 500ah lfp, it's been along time ago researching this so I could be mistaken.
Over the past 6 years with my lfp and using it in whatever SOC with high draw items for long periods of time and not needing to get them back to full like a lead pack should be also be thought about when comparing "price". With lead how often is a rv park needed or home needed to full charge on occasion to get longest life. Or long generator time to get back to full. How often is the equalization charge needed for long life.
All good points for that scenario.
You could do your daily 200AH with 500 of AGMs ok but as noted need to keep getting them to full. Having more than 500 of AGMs would just make it harder to get to full
To meet the 20% charging rate spec means 100a charger and big enough gen for it
It depends on scenario for each RVer if any advantage with LFPs. No use for me where 4 sixes are just right
I forgot about the proper % for charging lead whereas lfp can be done with hammering it if you have the ability or just give it a trickle.
So biggier with lead is not always better or atleast in a camper situation?
