Desert_Captain
Jul 09, 2020Explorer III
You don't say how old your coach is but when mine began to get difficult to smoothly operate after about 5 years so I just replaced the entire valve setup. The handle on the grey tank valve was developing a crack so figured better to do it at home with all my tools available and no pressure. I believe folks refer to this sort of thing as "Preventative Maintenance".
I ordered the replacement valve assembly off of Amazon {about $40 a couple of years ago} and had it in 2 days... probably would not be that simple out on the road. It took about an hour and half to pull the old one and install the new. Tip of the day: start with a clean and empty pair of tanks. :S
Spraying on lube or greasing up the exposed portion of the shafts is basically a bandaid solution once they start to stick. Better to get it done right and know that it will never be a problem during a trip.
Worked for me...
:C
Worked for me...
:C
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
