ernie1
Jul 11, 2020Explorer II
I quit using any petroleum products on the dump valve seals after figuring out that it was reacting with rubber in the seals and causing them to swell and when that happens either the slides were extremely hard to move or the seals become dislodged when pulled by the slides and all hell breaks loose along with the sewage. I now use a product produced by Dupont called 111 Compound which is a heavy bodied silicone based lubricant that will not react with the nitrile rubber based seals. Learned this from talking to the people at Drainmaster, a company that produces electrically operated waste line valves which ,by the way, has operated flawlessly for a couple of years now.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
