wa8yxm
Mar 20, 2021Explorer III
1: Does stat run both AC and Furnace? And 2:is it "electronic".
if it is electronic then it needs power.. Normally most Heat/Cool stats get poer from the "heat" side (Furnace) and run on a rechargeable battery during Heating cycles ... That battery may need replacement.
Some use replicable batteries. and again replacement may be needed.
I do not know about yours
Mine Factory the A/C itself (one of 'em) operated the furnace and drew house power.. When that A/C went bad I the new one did not have the ability to control the furnace. So we taped off those leads and I put a mechanical T-Stat on the wall. It did not need batteries.. and since it was "Mercury Free" it did not even need to be level.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
