CJW8
Jul 02, 2015Explorer
rjxj, fisherguy,
PV arrays can be larger than the controller input rating under certain circumstances. The controller needs to be able handle it but it can be done.
I have said this several times on here over the years but no one pays attention to it.
Solar installers do this all the time on residential installations. I have 15KW of PV on my home but only 13KW of inverters. Not a problem.
I am about to install 500 watts of PV array on my new RV with a 30 AMP MPPT controller. With the same controller I had 420 Watts (flat) and the most I ever saw was 27 amps out of the controller.
NOW, not all controllers will let you get away with this. I know Morningstar will. So will Blue Sky with solar boost. I believe my Rogue 3024MPT will also. Some lower cost controllers have no limit on the input and will simply shutdown when the output exceeds its limit. So I am not recommending this to anyone. Again, I am not recommending this to anyone. Know your equipment.
There are several real advantages to having a slightly oversize array. Better production on cloudy days, longer maximum daily production. There is also a point of diminishing returns so don't over do it.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
