RoyB
Aug 09, 2015Explorer III
I am doing the SOLAR INSTALL in baby steps with my OFF-ROAD POPUP camper.
I upgraded the on-board OCNVERTER/CHARGER unit, added more battery capacity, and changed over the trailer high wattage incandescent automotive lights to LED lights.
Been camping off the power grid all over this area on the East side of the US with this setup using 255AH battery setup. We do just fine with all the things we want to run doing this. We planned out our battery consumption to drop down to their 50% charge state hopefully at 8AM each morning when we are usually allowed to run our 2KW generator. We then connect our 30A Shore Power cable directly to the 2KW generator 120VAC RECEPTACLE using a RV30-15A Long Adapter (WALMART). This powers up our smart mode on-board converter/charger unit and will re-charge our 50% charge state batteries to their 90% charge state in just over three hours of generator run time. Then we can do this all over again the next day/night run off the batteries.
The batteries here demand over 50A DC CURRENT when first starting their initial charge run when first hit with 14.4VDC from the converter. This is more DC CURRENT than a single solar panel will produce in high sun. The 120WATT SOlar Panels will only produce around 5-6AMPS DC when in high sun.
Now that we have pretty much got the system we want to have for camping off the power grid for long extended it is time for us to add solar panels to keep us from running the generator so much.
Solar Panels are NOT much good for you unless you can store their energy into the battery banks to use at night.
Our game plan is to always use the generator for the first hour of recharging batteries which get past the high current portion of the re-charge. When the batteries start demanding lower DC current as they are being charged up then we can shut down the generator and just let the solar panels finish off the re-charge cycle. May take all day but as long as we can get to the 90% charge state before the high sun goes away then it would work for us.
Have learned from day one we have to always start our day/night camping run with our batteries at the 90% charge state or more otherwise it gets dark on us around 10PM at night. Then we would have to wait until 8AM the next morning before we would be allowed to run our generator.
This is the way it work for us at least...
My game plan is to install enough solar panels to produce around 20AMPS of DC CURRENT during high sun each day. My generator will always be available to run in case there is not enough high sun during the day.
These are my SOLAR PANEL goals - I'm sure others have their own game plan haha...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
