Rotzilla
Aug 10, 2015Explorer
We just installed a kit from the same company, 2 100 watt panels, and a mppt 40 amp controller. (40 amp allows me to expand to 4 panels later if necessary).
TH has 2 24 series batteries wired parallel.
From 1/4 to full charge takes approximately 4 to 5 hours of direct sunlight.
Other items you need to purchase that do not come with these kits are; inline fuses, one from pv panels to controller, and one from battery to controller are advised but not included. I also added a on/off switch to be able to disconnect the panels from the system. I can turn it on only when the system is in use, also to work on the panels without electrocution.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
