wa8yxm
Jun 29, 2021Explorer III
Ok an RV fridge is not all that energy effiencent. Normal power draw (When cooling) on A/C is around 350-450 watts.. A residential fridge of the same size.> Well let me go look at my apartment unit's label. .It says 4.5 amps at 120 volts or what 540 volt-amps.. What the wattage is (V-A*PF) it did not say or I did not see (Will have to do a photo shoot). but that will be less than 540.
The RV fridge V-A=Watts (power factor 1.0 for a resistor) and 360 watts is 3 amps. The "Rule of thumb" is that will suck about 36 amps from your batteries.
A GC2 pair (Single pair of 220 amp hour Six volt batteries) will NOT last 3 hours.
On propane it draws only a few amps and those same batteries will last for closer to 3 DAYS. (Assuming no other load or re-charge)
