westend
Jun 17, 2015Explorer
The symptoms you state are coincident with a worn tie rod end or worn ball joints. Any shop that works on suspension should be able to diagnose the problems.
Also noted: 70 lbs of air in minivan tires may effect the handling. You could try lowering the pressure and see if it helps.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
