Okay the marine layer ( low clouds) has moved in ending the EQ session 30 minutes after last report.
SG at 1.290 on all three with the battery now 11 degrees above ambient, and the innermost cell being the hottest adding 12 whereas the outermost was adding 7, and all coming within a .001 of each other when compensated.
It was taking 4 amps at 16.02v before the clouds moved in. Bubbling and gurgling up a storm.
This was the longest EQ session I have done by 90 minutes or so.
Obviously 14.7 and 14.8 are way too low for this battery in these temperatures.
About to reset ABSV and Float. Forecast is 62f low, 64f Highs through Thursday, which likely means lots of marine layer and not enough sunlight to get to or hold high 14's, and more Schumacher assist.
If the forecast holds true, then next Sunday's dipping might not add much data to better pinpoint solar voltage setpoints.
