landyacht318 wrote:
More Sunday Data.
Since last week, 14.8 ABSV for 2 hours or if Amps drop below 0.8a to hold 14.8v, 15.1v Float/finish.
30 to 45 A/h removed each night.
Battery rarely touched 12.1v under 9 to 10 amp loads. Better. performing well, IMO.
Almost no alternator assist. No Schumacher. Solar plentiful daily. 15.1v for several hours daily. Mild temps all week, 62 to 75f range
Today Dipped hydrometer about 1 hour after it went into Float at 15.1v.
Taking 1.1 amps to hold that 15.1v
SG 1.270, 1,270, 1.265. This is the highest Initial SG reading I've seen, after a week of cycling.
Switch loads to AGM increase to 16v for 31. 6.2 amps required to reach 16v.
1/2 hour later 1.280, 80, 75........still taking 4.2 amps
1/4 hour later 1.285 1.285, 1.285...Still taking 3.8 amps
1/4 hour later 1.285 all three....... taking 3.2 amps
Terminate EQ cycle.
I guess that 1.290 reading I once got a few weeks back, was incorrect
14.8 ABSV apparently makes a big difference over 14.7v with this 31.
Forgot to put on junk clothes before removing cap. Fumbled cap, GOt it on new 50$ boardshorts. Rinsed within a minute. Bleached camo colors to white, but material is some variation of ripstop nylon, still intact, so far.
Pretty sure that I'm narrowing down on that voltage/SG sweetspot 14.8v absv and 15.1f, and a weekly EQ blast of 16v for 45 minutes. This is acceptable to me, and hopefully not too aggressive on (+) plates.
I am not missing that extra capacity of 2 27's vs this single 31.
And what Mexicowanderer has been saying all along makes the difference. Wait until we get some high 90F to 100F temps, and I bet your SG comes back up again to that 1.290.
As an experiment, take your battery up daily to 14.9V, Float at 15.1, and I'd really be interested where the SG sits after a week of such treatment. It would most likely require a pretty short 16.0V blast to de sulphate, in this particular model of battery.
You will always get better chemical reaction and longevity, amps wise, from batteries in the summer time. Winter is another matter, due to temperature drops, and requiring so much more Voltage to push things in and top them off. Higher temps = higher potential for chemical reaction, the molecules are bouncing around faster at higher temps, more chemically reactive.
How is your electrolyte level holding? I'd think you'd want to add more water and run it on the high side in the summer to make the battery last longer, and run it lower in the winter time, to bump up the SG in the colder weather.
