On march 17th I filled all cells to 1MM below the arms.
Tonight, that level is now 1Cm below the cells.
So much increased water usage. Performance ( voltage under load for same AH removed) is dropping, but has not dropped off the proverbial cliff
At 15.3v it was taking 2.4 amps and this number did not taper at all in 2 hours.
So I popped a cap and dipped my Hydro.
The weak cell closest to the Negative battery terminal was
1.245
1.270
1.275
I just cranked my MeanWell upto 16V. Required 6.45 amps to get there.
Cycling the AGM tonight Looks like i'll have to hammer those good cells to get the weak cell up into the green. Ill see how long it takes. Hydrometer was saying to subtract 0.004 at 15.3v.
