15 minutes later. No change in amperage required to hold 16v
1.247
1.271
1.278
Correction the two stronger cells have used 1 CM of water, the weaker cell has used barely any.
30 minutes into EQ
1.247
1.274
1.281
6.74 amps to hold 16v. Rising.
45 minutes into EQ
1.249
1.278
1.281
7.12 amps to hold 16V tapered to 6.92 at 15 minute mark.
1 hour into EQ
1.250
1.278
1.281
7.22 amps to hold 16v. Strong cells showing a bit cloudy, weak cell still clear.
Uncomfortable with the amps rising, but battery temperature is not increasing quickly, neither is SG for that matter.
1hr 15 minutes into EQ:
1.252
1.279
1.281
7.62amps to hold 16V
Lowered voltage to 15.88. 6.5 amps
Gonna try and just hold 6.5 amps at this point.
