BCI group L16. So it's 15.73" sue me.
"EXPECTED LIFE VS. TEMPERATURE - Chemical reactions internal to the battery are driven by voltage and temperature. The higher the battery temperature, the faster chemical reactions will occur. While higher temperatures can provide improved discharge performance the increased rate of chemical reactions will result in a corresponding loss of battery life. As a rule of thumb, for every 10°C increase in temperature the reaction rate doubles. Thus, a month of operation at 35°C is equivalent in battery life to two months at 25°C. Heat is an enemy of all lead acid batteries, FLA, AGM and gel alike and even small increases in temperature will have a major influence on battery life."
-Have issues with the above paragraph?
Trojan Battery will be happy to discuss them with you. The quote marks were inserted for a reason.
