Fisherguy's avatar
Fisherguy
my solar install
Thanks to a LOT of people's help on this forum my panels are up and working.
I got my 120 watt panels, MC4 cables, Tristar 45 PWM contoller and TS-RM-2 display from Solar Blvd who matched the prices of the controller, display, temp probe etc I got from Ecodirect, I thought that was pretty good.
Instead of a 'combiner box' I used Blue Sea feed through posts in the fridge vent, they're not exposed to much UV at all under the fridge vent so I'm pretty confident that won't be a problem.
I ran 4ga down the fridge vent, through the floor into conduit underneath the trailer coming back up in the front cupboard then over to the are under the front sofa where my PD-9280 and 600 watt inverter are located. I ran the output of the controller to the 4 ga cables going from the batteries (through a fuse) to the inverter.
Used a 50 amp breaker on the 4 ga from the panels to the controller.
Don't like the idea of the 'Z brackets' most places sell so I made my own out of aluminium angle and stainless hardware.
Other than the length going to the first panel all the cable is held in place to the bottom of the panels. I made the brackets for the front panel slightly different so it's tilted a bit otherwise it wouldn't have had any tilt at all for water to run off, might help tot avoid lift too maybe..?
The most I've seen them put out so far is 16.5 amps, I think I woulda got a little more as the sun got higher but right then it dropped down to 'absorption' mode. By adding a Y-connector to the cable feeding the lst panel I'll be able to add another panel in the future, something tells me that will be in the spring! ;)
Thanks to everyone who helped me out, and sorry for all the stupid questions the last little while.
Will
Feb 2017, edit
August 2016 I picked up another 120 watt panel from Solar Blvd, they must have a new supplier, this one seemed to be maybe a little better made with a slightly beefier frame, the finish on the top of the panel is slightly different as well.
I added it on the left side of the trailer 'wyeing' into the cable that was coming from the panel in front of it, so now we have 480 watts on the roof.
Also a pic of the bracket I made up and the stainless screws I used, think they were 12 x 1.75" long.
So far no complaints, even added a pigtail off my trailer batteries I use for charging my boat battery, of course doing that screws up the readings on my Trimeteric until I reset it once the boat battery is removed.
  • Nice job. Only thing I would comment on is that I would have been more generous with the sealer on the solar panel mounts to the roof.
  • RoyB's avatar
    RoyB
    Explorer II
    I like your BLUE SEA feed-through idea
    I've been contemplating using PVC Electrical BOXES mounted on the side of the trailer up at the roof line for mine but the UV's may be too much for that over time...
    I already use the PVC Electrical Boxes (LOWES) idea for gaining access to the roof area with RG cables and I guess they are surviving ok being in the sun... Having weathertight removable lids sure makes it great for keeping track of the cables... I do the same thing for my 4AWG battery cables at the floor level coming and going to the battery banks...
    My goal is to install whatever I come up with to give me around 20AMPs DC Current when in the high sun.
    I have already decided to always make my initial DC Charging using the 2KW Honda Generator running my shore power cable to get past the high current phase of 50-60AMPS DC current demand by the batteries for the first charging hour then if I have high sun will allow the panels to finish my charge state until the high sun goes away each... I will always start my run off the batteries with them at their 90% charge state otherwise it will get dark on me around 10PM at night and I have to shut down everthing when I see 12.0VDC on my meter panel. Presently this is occurring at 8AM each morning when I am usually allowed to run my 2KW generator with all of the generator run restriction I usually run into here on the East Side of the USA.
    The joys of living out West with all of the vast primitive camping areas available to you sure has its merits... Even our Natl Forrest areas have generator run time restrictions here...
    After doing this I may change my mind using this method but for me this is the best for sure method of always starting my day/night run off the batteries with at least the 90% charge state. I will be drawing in the mid 20's amps from 6PM to 11PM with my planned power draw.
    Keep us informed on how thing go with your initial solar runs...
    Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
