Almot wrote:
bka0721 wrote:
As for the cables the OP was working with, some of his issues with routing the wires could have been alleviated with using wire/cable from a welding supply center. Having the flexible wire/cable will aid in longevity in a vibration filled environment, of an RV. The OP will need to recheck the cable and connectors more often, than someone that used a more flexible cable for their install.
I don't see where and how his panel cables go on the roof and through the roof, or how they are connected on the roof, but it looks not unlike #10 or #12 that came with panels. It's a pretty thin cable, more "springy" than flexible.
I didn't see them either. I suspect you are probably correct, but you are just guessing. I was referring to the cables/wires the OP was referring to and had in his pictures. The OP did some really good work and I like the panel that was used in organizing it.
b
