opnspaces
Jul 17, 2014Navigator III
OP, I would probably just do the 12 months routine. To be truthful though I only do mine every few years.
I found the Dexter axle FAQ's today and found a snippet about E-Z Lube and bearing inspections (I added the red for emphasis below). Dexter FAQ's
E-Z LUBE - What is the E-Z Lube option?
The E-Z Lube option was designed specifically for the marine application where the axles are constantly being immersed in water. This feature provides a convenient method for purging the water from the hub cavity without having to pull the hub every time. The hubs should be removed every 12 months or 12,000 miles to inspect the bearings and it is imperative to replace the seal at this time to assure that the grease does not leak out the back onto the brake linings rendering the brakes non-functional.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
