ernie1
Feb 21, 2014Explorer II
If you put the "little white chunks" that are coming out of your faucets into some hydrochloric acid (same as muriatic acid for pools) or CLR (Calcium Lime Rust) it should dissolve and then you'll know it's hard water minerals and not plastic nor paper fragments.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
