Mamacast's avatar
Mamacast
Mystery with Suburban furnace
Hi all, I have posted this on another site as well hoping that someone might have run into this before.
During this past trip we could not get our SF 30 to run no clicking no blower, nothing. We checked the fuse and that was in tight, removed it with pliers and it was in good condition so replaced it. Voila, the furnace started right up and worked fine for the entire trip. When we returned home we turned the furnace on to keep the lines from freezing since winter has a death grip on CO. and again it wouldn't work until we pulled the fuse and then put it back in and then it worked great. Is there a reason that we are having to pull the fuse and re seat in order to get the furnace to work, and what might the fix be? Thanks for any and all input.
  • sounds like a faulty control board. What you are doing is resting the controls. Try resenting the T-stat.
Having RV issues? Connect with others who have been in your shoes.24,203 PostsLatest Activity: Feb 21, 2025
