JimInMich's avatar
JimInMich
NAPA Commercial 12v Battery ( Amp Hour? )
My MH came with two of the NAPA Commercial 12v batteries (part#7236) as my coach bank. I read people chatting about having 220amphour, ect. I don't see that rating on this battery. Is there a formula to find out?
From the NAPA web site:
Battery Application Commercial
Battery BCI # BCI # 31S
Battery Cold Cranking Amps @ 0 Degrees F 950
Battery Cranking Amps @ 32 Degrees F 1,190
Battery Load Test Amps 475
  • Matt_Colie wrote:
    Jim,
    Are you having capacity issues with what you have? If no, clean the terminals and leave them alone.
    No isues yet, we just purchased this MH and I am trying learn what I can about it.
    The fact that it came with 2-12V jars is already kind of telling. A pair of golf cart batteries will probably be better than what you have.
    What does it tell?
    Yes, I'm sure that 2 gold cart would be better.
  • Jim,
    The PD9260 is a good converter for that, just make sure that the terminals on everything are clean and tight.
    Matt
  • I know about using two 6v. I was hoping to save the cash for something else. I'll have to wait and see how these do.
    And charging is via PD9260C.
  • A 15 plate 2% antimony battery. Thousands hit big rig dealer parts shelves and were retailing for $79.95 exchange. Not at all a cyclavle battery as Ed Gee so nicely put it. Flooded 31 batteries are problematic no matter what plate configuration is used. I recommend a plain "pass" on that BCI group size. The batteries are 13" in length so 11" 3-cell golf car batteries would fit if your intentions are to boondock. Always plugged in? Those NAPA batteries would be fine and dandy. There are no issues with 31 VRB absorbed glass mat batteries.
  • Our used TC came with a NAPA battery like that. Called "HD Commercial" and I could not find any AH for it, but it weighs 56lbs as a 31 so I figured not much. I did find a similar NAPA battery somewhere Googling around that was about 1,000 CCA and had about 80AH.
    IMO, if you will be on shore power mostly, they will be ok, but if you plan some off-grid 50-90s, swap them out for proper deep cycle batteries for the house bank.
  • I would guess 220 combined is about right. Maybe a little more.
    Do you need more power? What are you charging with?
    Many house batteries are chronically undercharged and lose capacity.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    130 amp hours each is my guesss. the key spec was the #31
    A group 31 battery is about 130 amp hours.
    HOWEVER: From the ratings I'm guessing a Marine Deep cycle
    Thus two are 160 AMp hours but you can't use all that, IN fact you can't even use 130 of it, only about 100 amp hours are usable after that damage sets in on the batteries.. So the GC-2, where you can safely use HALF the battery, (It is a DEEP CYCLE not a MARINE/deep cycle) is a better choice.. Or better yet, upgrade to 2 pair of GC-2
    Each pair wired in series to get 12 volt, is treated exactly as a SINGLE 12 volt battery.
  • An AH rating may be available, somewhere, but this is really a heavy duty starter battery ... not a deep cycle battery designed for RV use. Consequently amp-hour specs are usually not provided. It is designed for short high current draw for starting engines, not for long moderate current draw over many hours. The physical design of the plates are quite different .... a proper deep discharge battery has much heavier plates. The GC2 type battery, in pairs of 6V types, is pretty much the standard for motorhome use - and these are also costlier .... but they tend to have longer life spans and provide more amp hours per discharge cycle than starter batteries ... or even the mid-way Marine Deep Cycle types.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 19, 2025
