Likes_to_tow
Jul 28, 2026Nomad
Nautilus P1 has leaking connections
I'm totally stumped by my inability to stop the swivel connectors to stop leaking on my Nautilus P1 system !! I first noticed a slight drip when the valves were in position to power fill the fresh ...
- Jul 30, 2026
I found my leak. It was in the threads of the manifold. I pulled this manifold out three days ago so I could get an up close examination. I expected to see a crack or a deformity but it looked perfect so I re installed it. Changed the swivel connector twice but it still leaked. Changed the cone washer seal 3 times using different brands. The tighter I tightened it the more it leaked. I finally ordered a new manifold and that cured the problem. I don't know why this leak started because I have winterized properly each of the 9 years I've owned this trailer. So if anyone has a leak and changing the swivel connector or cone washer does not correct it then order the section of manifold you need. $$
