darsben1
Aug 07, 2017Explorer
Look around for a GFI outlet and reset it. The outlets could be cascaded from the GFI. Also check your circuit breakers by turning off and on not just a visual check.
Can you get to the outlet for the fridge and unplug it? Then use an extension cord to plug the fridge into a known good outlet. If it works then if none of the troubleshooting I mentioned worked I would unplug the rig and tighten down my wires in the circuit breaker box to make sure none of them has come loose
