BFL13
Aug 07, 2017Explorer II
The fridge needs 12v to run on 120v or on gas. So the fridge isn't getting 12v. Why not? Other 12v things work. Why will the converter not supply 12v or the battery to the fridge?
The converter might not be getting any 120v on its receptacle if it is a plug in type, but then why isn't the battery doing the 12v instead? There is a battery disconnect switch, but some 12v is happening in part of the rig, so "not clear."
One set of 120v receptacles works but the other does not--is this a 50a rig or a 30a rig? Is the converter on the live or dead set of receptacles?
Agree to check for a popped GFCI receptacle in the dead circuit of those just in case.
