mojoroo's avatar
mojoroo
Need a battery. Never boondock. Recommendations?
My battery is toast, leaving our TT plugged into shore power has ruined our battery. So I need a battery, nothing to boon dock with but something to give us power to open the slide when arriving on the site, getting lunch at rest areas and the occasional power outage.
So what should I get that is fairly inexpensive. I assume I don't need a true deep cycle.
Also what should I do to keep the rv charging system from over charging?
  • Buy a really INEXPENSIVE multimeter. One that the test leads are permanently attached. You can find these online. Five dollars or so.
    Set for VOLTAGE DC
    Touch RED + test probe to battery POSITIVE post, nowhere else
    Touch BLACK - test probe to battery NEGATIVE post, nowhere else
    The numbers on the dial have a decimal point. Note it. (example 14.34)
    Rake a reading and come back to the forum and post your results.
    Set for VOLTAGE DC
    or "buy" one at harbor freight, for free.
    :) bumpy
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
