MrWizard
Apr 01, 2016Moderator
diveman52 wrote:
That's interesting but it does not give you a range of wire sizes it will accept. Just looking at the pic looks like #6 or maybe 4.
To be 150 amp would require something like 1/0.
to be precise
to carry 150 amps at 12v with out voltage drop, would require substantial wire
but make a terminal strip, that can carry 150amps
put 6ga wire openings on it
and you have a mil-spec terminal strip that will carry 50amps 24/7 and never fail
rated for 150amps, does not mean the original intended work load needed that much power
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
