CA_Traveler
Jul 13, 2015Explorer III
The obvious solution is to run a new pair of wires so that you know exactly what you have. As I recall you've run wires before so...
Have you checked the Sunsaver controllers? Not sure what it controls and the manual does show isolated array input.
My MPPT 60 has common negative and hence grounded connections if that is a option for you. Maybe check the higher powered MS PMW controllers.
Let us know if the DC-DC converter works OK.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
