rcksblr
Aug 25, 2020Explorer
jdc1 wrote:
100amps/day is what a 20 cubic fridge/freezer uses. One $899 battery will work for a day. You'll need a different charger.
The fridge is a Danby 7.4 Cubic Feet. Sticker says 344 kWh annually. So if I do the math that is somewhere around 80 Amps/day. Which is a lot, no doubt.
My thought in this application for the Lithium battery would be that I could run the Generator for a few hours a day to recharge the battery to keep things maintained while camping. I also have the solar panels I could keep plugged into the battery as well while not running the generator. I do have two separate standard RV/Marine batteries (845 CC amps) in the battery bank up front that are tied to the Fridge battery so that would help as well.
