MrWizard
Aug 28, 2020Moderator
Moving the 3rd battery will keep all house batteries at the same voltage,
But unless you replace the wire going to the inverter larger gauge wire going directly to the batteries, the inverter will still see voltage drop on fridge compressor start up
The battle born tech is referring to charging voltage at the battery
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
