westend
Sep 18, 2016Explorer
You need to get the subfloor stable to install laminate over it. IF you have failed foam core and sheet rot, it needs to be replaced with new material.
Typically, walls are installed over the floor deck but that may not be true with all.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
