dougrainer
Apr 30, 2015Nomad
1996---Take the cover off the rear main control module. IF the Epoxy resin on that module board is beige/tan, the ONLY fix is to replace the Module board. Those years (1993-1997) were the years Dometic had bad module boards that Intermittantly went to check for LP,EVEN IF ON AUTO and not calling for LP. There are 2 parts- The Module (updated) and a Ground Loop harness that needs installed also. If your Module board is NOT beige but greenish in color(meaning that the board is the updated module board), then do what Chris advised. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
